Hi David, is there an update for adding multiple gear to an activity?
I accidentally deleted a bike, how do I recover it?
Hi David, I’m new to the platform, and I want to thank you for your work!
I’ve noticed some strange behavior with the running shoe gear calculation. When I press the “Calculate” button, the distance and time are both set to 0.
If I manually assign gear to an activity, it gets added and calculated correctly. But as soon as I press “Calculate,” everything resets to zero again.
Interestingly, it seems to work fine for bike gear - at least I get some values there.
I guess it’s my bad. Calculates properly if set “Purchased” date correctly.
Is it possible to create a reminder that started in the past? I want to change the “Usage calculated since day x”.
Not seeing “Indoor Gear” as an option.
I may be missing it, but I see “Default Gear” but not “Indoor Gear”.
