The average speed field is not showing in the interval box.
I have tried:
- Tick/untick
- Move up/down
- Untick other fields (suspected max no. of fields)
- Other activities/rides
None of the above fixed it.
I think that is because you don’t have the Speed chart enabled.
Aha. That solved it
Hmm yes I need to work on the UX a bit there. Thats not obvious. Should just make it not dependent on the speed chart showing.
I have just sorted this out. You can now add speed and other fields without having to also show the corresponding trace chart.
