Is it possible to allocate 2 pieces of gear to an activity by default for instance a bike, and a trainer for for virtual rides, if so how? Thanks in advance
Is there a general solution? My gravel bike has two cranks, one with crank power meter (gravel 2 cleat shoes), and one with Garmin road power pedals (road 3 cleat shoes). Therefore 2 PMs for 1 bike.
Iām using Strautomator and it supports OR condition.
Ugly workaround
Hours and miles donāt align. Something else to fix. Sigh.
Davi, tudo bem?
seria possĆvel usar o sensor de cadencia ao invĆ©s dos medidor de potencia?
Hey David
Is there a way of doing this based on the connecting shifting.
E.g. I move my assomiaās between my road and TT bike but they both have AXS so I could I say this shifter is for this bike and that shift is for that bike?
Thanks ![]()
Excuse me. Where I charge my shoes? I dont understand
If you are looking for how to add gear, itās on the settings page:
Once added, set default gear for each category of sports.
Sorry, please.
The question was very very easy.
I am bad.
Sorry
How are they supposed to match? I have same names in Strava and here, but the gear does not show up.
Also, when I click on activity type icon in order to choose a gear, the gear drop-down list is empty, nothing to choose from.
You need to give Intervals.icu permission to update your Strava activities:
Click āUpdate Permissionsā in the Strava box in /settings.
Gear is matched on id, not name. Gear copied from Strava (āUpdate From Stravaā) has matching id.
Thanks for the answer. I donāt like the idea of updating my strava activities.
Iām not sure if this is a glitch or by design: for āWalkā activity I have a defailt shoe on Strava, but for this particular activity I chose to leave the āshoeā field in Strava empty ā it is however filled by the default value in intervals.icu
Also, it turns out that I can choose (but not save) āshoeā via window that shows up on a click on the activity type icon: if I press a key so that the letter corresponds to the first letter of a shoe name, that name shows up in the field. But only the first one if there is several on that letter. If the list is available, why not show it and let the user save what they want? Just a thought.
That window doesnāt let you edit because you are getting activities from Strava but have disabled updating your Strava activities. So changes on Intervals.icu would be overwritten by data coming from Strava.
I am not sure why the drop down box for gear is misbehaving.
is it possible to see the gear distance progress over a time range?
Greets
Auto assign gear to activities using filters working ok within Intervals.icu however it wonāt update gear in Strava.
Manual assignment of gear in Intervals activity is updating gear in Strava, so not sure why the auto assignment is not updating gear in Strava when Route Name and type defined in Intervals would update Strava automatically.
Auto assignment of gear has stopped working for me. Why? This run should have been assigned the Asics Metasspeed Sky+ shoes because itās tagged as a long run, but it gets the default shoe. @david ?
What was your final decision on this? Is it possible to make an āorā?
I cannot for the life of me get this to work. I have Intervals connected to Hammerhead and Strava. Both the Hammerhead dashboard and Strava will list the correct gear and ride type for each ride, but Intervals keeps defaulting to one of my bikes and āRideā ride type, even when I use my other bikes with other ride types. Itās driving me nuts.
@david Hi there! Iām tweaking my gear filter after noticing the last few runs were incorrectly processed (my fault on this). It looks like the best for my use case would be allowing OR matches on the name, but this is not there yet. Any ideas on a workaround?
My runs (which need to use a different gear) are all using a very specific name. I need to match the ā2nd gearā on these names only:
- ST 8x4min
- ST 4x8min
- ST 3x12min
- LTHR Test
The closest I could do is to add a single name match for ST and manually updating the LTHR Test. Originally I put all those four names in a filter but it didnāt match anything (for obvious reasons).
can you let me know how this worked out? Iām having trouble making a ābikeā component beneath the bike category. Thanks
