Are Strava Segments down?
Hi all,
I am wondering whether the function to add Strava-segments is currently not working.
Did a ride today that is also on Strava, but for some reason, the segment option when hovering the cursor below the graph is not active.
And the “For Segment (V)” option is missing as well.
cheers
alfred
Update:
in todays ride segments are back again.
However, for yesterdays session they are not available??
Not a big issue, just curious why this happened, any ideas?
There are some race conditions in the code that copies segments etc. depending on the timing of the incoming activities. I undeleted the Strava activity so it re-synced and copied the segments then deleted it again. So that activity on the 14th now has segments.
If you do this you need to reload the page after the Strava activity has synced to see segments on the other activity.
thanks David > fixed
