Aero Analysis Tools
Hi David, at some point it would be nice if we could estimate a CdA for the whole ride or at least laps/intervals. We know the caveats of this, on the other hand the rules for estimating CdA are always the same:
  • Multiple laps without braking or out and back
  • Minimum of wind or disturbances (cars…)
  • Estimate of rolling resistance, driver&equipment weight, Air Density, wind speed and wind direction
  • Accurate Speed Signal (from wheel Sensor, GPS too noisy)
  • Accurate GPS Elevation Signal
  • Not perfectly flat route
There is the Cheung Method which compares GPS Elevation with a modelled Elevation from a simple bicycle model (basically Force or Power formula) solved for the gradient. Then you adjust your estimated CdA value until you have the best correlation for your two elevation curves.
I know this could be quite time consuming to develop and possibly needs a lot of server power for the calculation (minimum error search to find best-fit CdA). This is not a common utility tool, but I like to play around with it, even when I am only riding a road bike.
It could be also done without a minimum search, but maybe only for finding an average pseudo CdA for the whole ride…
I never developed such a tool, but could help with some links.
The time consuming part would be the coding, server power not likely to be an issue. I have added this to the todo list.
The Chung field method is nice, but is it time consuming? Plus you need a really calm day and a flat stretch of road. Curious about your experience with this to warrant an add-on to intervals.icu.
Hello @david. Is the Chung method feature likely coming?
Method detail:
http://anonymous.coward.free.fr/wattage/cda/indirect-cda.pdf
Rober Chung video explaining the method:
Plus, it looks like some implementations are already available for reference:
This thread seems quite old, but I would also look forward to such a feature :slight_smile:
I’ve made an Custom script for that, search for “CdA”.
Awesome, thank you!
