Hi David,
Could you add Wattbike Hub to the Connections list alongside COROS, Garmin, Polar etc.? Wattbike has a documented partner API (TrainingPeaks, TrainerRoad, Strava all pull from it) so the integration precedent exists. Would massively improve the indoor-trainer workflow for Wattbike users feeding training data into the Annual Plan Builder. Thanks!
+1, I’d really love to see this too.
I’m a BMX Race coach (and rider), and our weekly key test is a 6-second Pmax sprint on the Wattbike. Right now the only way to get those rides into Intervals is through Strava, and that’s exactly where it breaks down for sprint work:
- Strava resamples everything to 1 point per second. The Wattbike records per pedal revolution, so on a 6-second effort the peak power and peak cadence that reach Intervals come out smoothed, and they don’t match what the Wattbike actually measured.
- We lose the Wattbike-specific data along the way (per-revolution power, left/right balance, pedalling-effectiveness metrics).
- Activities that come in via Strava are restricted on the Intervals API side, so they can’t be fully analysed or reused in scripts.
At the moment I’m working around this with an unofficial script against the Hub plus manual exports from the app. It works, but it’s fragile and depends on me as the coach for every athlete.
As keafeather mentioned, Wattbike already has a partner API (TrainingPeaks, TrainerRoad and Strava pull from it), so a direct Wattbike Hub connection would give Intervals the real per-revolution data. For sprint and power-profile work (BMX, track, team sports), that would make a huge difference.
@David , would you consider looking into it? I’m happy to test with several athletes’ accounts if that helps.
Thanks for everything you do on Intervals!
