Add planned RPE on Workout Builder
Hi Team,
There have been a few requests for RPE-based workouts. As a starting point, please could you consider adding a field to capture the expected RPE value in the workout builder dialog box. This allows coaches (and self-coached) to compare the planned vs actual, then ask why the athlete felt it was <> than expected.
As there are two scales in use, 1-10 and the 6-20 (Borg) perhaps it could be defined on the /Settings page. There could be an option to select which scale is used. The value on the workout builder would have a drop down value, or validation rule, to use the scale chosen from /Settings.
Edit: at the moment, it’s in the description, and a little harder to use automated processes to pick up the differences. Not impossible, just harder.
Edit2: the field for API use could be “icu_planned_rpe1” and “icu_planned_rpe2” for each scale.
