Hello all,
Is it possible to add a custom achievement to an activity so that it shows in the fitness graph as well?
I cannot find and option to do so within the activity view.
Hello all,
@david
Just wondering whether this is possible, thank you
Not exactly custom achievements, but you can do pretty much the same with custom fields. Add a custom field, then either calculate it using JavaScript or populate manually, then create a custom graph to show those on the fitness page.
@Andrey_Zonov Thank you. I will give your idea a look.
