Add chart for electronic shifting data (etap, di2)
Hello,
i am wondering if its possible to add a chart with the electronic shifting data… to compare per instance on which gear ratio i was when I was on that 10% hill at 290w.
the electronic shifting data is on the fit file. as I can display it on the my axs application that i have linked to my garmin connect account. I can also see it in di2stats.com.
unfortunately I cannot see this data on garmin connect either.
is it possible for you to extract the shifting data from the fit file?
Check this
