I have an activity from today that originated in Garmin. It’s something I do everyday. Right after the activity was done, I went to look at it in Intervals as I often do, and there were errors about Garmin syncing that I had never seen before. I figured it was a temporary issue that would right itself later.
It appears the activity later synced from Strava (I have Garmin syncing to Strava). Usually this particular activity shows up in Intervals for me with links to the Garmin and Strava sources. In this case it is only showing up with the link to Strava. In this particular case it’s a weight-training activity and normally it will get the kilograms lifted from Garmin but in this case I had to enter it manually into the Intervals activity.
I’m just curious if this happens in the future again if there’s a way I can force the activity to sync with Garmin? I tried going into settings and reimporting for today from Garmin but that didn’t do it.
