I used it, wasn’t impressed with heart rate accuracy
I use HRV details from the activity to look for ectopic heartbeats as well as HR record quality. Its a good way to know if your strap is going bad. That being said, is there a way to display those details on this platform similar to Runalyze?
How do you check for ectopic beats in the runanylze HRV data? Would love to track mine
You can see ectopic beats in your activities as a deviation in the HRV data. For instance, a PVC will fire prematurely and have a compensatory beat. I don’t believe a PAC would be observable in HRV data. So, in the data, you’ll see a datapoint above the line, and a datapoint below the line. PNN50 is a pretty good indicator of “burden,” but can also be skewed by bad data such as static electricity on the strap or excessive movement.
H10 on Fatmaxxer app can be used to store 10sec ECG strips when anomalies are detected.
Fatmaxxer is Android app.
Fitness HRV is a Windows app able to register full time ECG and has basic ECG diagnoses. Also H10 sensor and off course only indoor…
I knew that the H10 had been used in research settings for ECG, but didn’t know there was an app out there now. Very cool!
Hi @ss29672
I created “RR Raw Intervals *” and “PVC Detection Dashboard” Activity Charts just for that.
Activity Charts supporting Garmin HRM internal memory (for Swim activities) rr recording are working as proof of concept, but needing some tweaking from intervals.icu regarding icu.fit.hr to icu.streams.hrv translation, as icu.fit.hr isn’t available for use in Activity Charts.
Also:
“Hybrid NN/RR percent” Custom Stream and Custom Activity Field, also for Swim activities done with Garmin HRM with internal memory.
“NN/RR Plus” and “PVCs PSVCs Blocks *” and “PVCs PSVCs Blocks * (Swim)” Custom Activity fields
Oh very cool! It looks like it is able to pick out the PVCs. I agree with your examples that those are likely PVCs. Its a pretty consistent signature in the RR interval. Good work!
How can I install these graphics? I looked into "personalized graphics (or maybe is charts in the English version, I use Spanish, Gráficos Personalizados) and none of these appears…
Try
1 Create a new Tab and call it HRV
2 Open Graficos de Actividades
3 Choose Grafico Library
4 Search for the desired grafico
Hope this helps
Thanks Pepe, it did help! I was looking at the wrong place, Aptitude instead of the Activity itself…now I see the data. Will work to learn to interpret it…I’m a doctor, but a surgeon, so, you know…rsrsr
Great.
But is important too keep in mind that:
RR interval analysis alone can only provide a suggestive pattern—for example, a short coupling interval followed by a compensatory pause—but it can’t definitively identify PVCs. Many rhythm irregularities (e.g., PACs with aberrant conduction, atrial fibrillation with variable block, or even noise artifacts) can mimic the RR signature of PVCs.
True confirmation requires the morphological features of the QRS complex on an ECG (wide, bizarre, no preceding P wave, discordant ST-T changes). So while RR-based PVC detection is useful for screening or trending, it should always be treated as a hypothesis, not a diagnosis.
Solid. As I have a DA stent I’m always paying atention to these details…a holter I had a while ago showed some idioventricular rhythm, but the eletrofisiologist considered them benign, so I keep the train rolling…this data can help me to keep an eye on it…great work!
Custom Activity Fields (Personalizado>>Campos de Actividad) “NN/RR percent *” and “PVCs number *” are also great to have and track in a Fitness chart (Aptitud)
“NN/RR percent *” tracks
(Number of “normal” intervals) / (Total intervals) × 100
A “normal” interval must satisfy both:
Duration between 250 ms and 2000 ms
Within 20% of the moving average of the previous 20 intervals AND the moving average of the next 20 intervals.
This is great to quantify Heart Rate recording quality.
“PVCs number *” returns a number, easy to track in a Fitness chart (Aptitud)
“NN/RR + PVCs” Fitness Chart (Aptitud) completes that.
Now custom streams DFAA1 (detrend fluctuation analysis alpha1 ) and RF (respiratory frequency) from icu.streams.hrv, or my m132HRV custom stream for Swim activities done with a Garmin HRM with memory.
Thanks for these graphs,
What does it mean the double (or x3 or x4) data points? Maybe a failure in the sensor, skipping some beats? I tested the graph in my last trining and I also saw a few x2 and a pair of x3 measurements
What chart? Can you attach a print screen?
Of course, I attach two pictures (the full trace and a zoom os a doubled measurement). There are approx 20 points with a x2 measurement and 2 with a x3 measurement.
You can check your activity plot values against you activity icu.streams.hrv
Limitations
Not for activities with pauses.
Note that if the stream has more than 10000 datapoints, there will be downsampling before plotting,
