Hi all,
Some of the activity fields I have added are not populating from me and instead have a ? instead of a value, any ideas why that might be.
Sean
Hi all,
Sean
Have you re-processed the activity since you added the fields? Try this if not and see if they populate.
You´re syncing from Strava only and the majority of your non populated fields are Garmin special fields. Strava strips those out. You will need to get the original FIT file in some way.
Hi MedTech thanks for that. I will give it a go and see if I can FIT file in
Sean
Yep tried this but I think it as MedTechCD says Stava is stripping the data out.
Sean
Did I , that must have been an accident on my part sorry
I have one custom activity field, that doesn’t populate automatically when activity is sync from Garmin. Have to reprocess manually to get the results.
Strava being Strava here I guess
