Activity chart layout
I created a custom activity pie chart for my heart rate zones. It’s all working, but how do I get the chart to align with the other charts, or how can I have two charts on the same line, next to each other?
Hope my question is clear.
Script:
 * Generates a Plotly pie chart displaying heart rate time spent in intensity zones (i1-i5).
 * - Includes "Below i1" as a separate category.
 * - Slices represent time in seconds.
const finalChart = (() => {
    const activity = icu?.activity || {};
    const streams = icu?.streams || { get: () => undefined };
    // Define heart rate zones
    const HR_ZONES = [
        { name: "Below i1", lower: 0, upper: 99 },
        { name: "i1", lower: 100, upper: 137 },
        { name: "i2", lower: 138, upper: 156 },
        { name: "i3", lower: 157, upper: 166 },
        { name: "i4", lower: 167, upper: 175 },
        { name: "i5", lower: 176, upper: Infinity }
    const ZONE_COLORS = ['rgb(200,200,200)', '#b6ffd3', '#6cea9f', '#fff871', '#ffbe57', '#ff8383'];
    let movingTime = activity.moving_time || 0;
    let heartRateData = streams.get("heartrate")?.data || [];
    let timeInZones = Array(HR_ZONES.length).fill(0);
    // Assign time to each HR zone
    heartRateData.forEach(hr => {
        if (!hr || hr < 0) return;
        for (let i = 0; i < HR_ZONES.length; i++) {
            const zone = HR_ZONES[i];
            if (hr >= zone.lower && hr <= zone.upper) {
                timeInZones[i]++;
                break; // Ensures each HR value is assigned to only one zone
    const formatTime = (seconds) => {
        if (isNaN(seconds) || seconds < 0) return "Invalid time";
        const h = Math.floor(seconds / 3600);
        const m = Math.floor((seconds % 3600) / 60);
        const s = seconds % 60;
        return [h && `${h} hour${h !== 1 ? 's' : ''}`, m && `${m} minute${m !== 1 ? 's' : ''}`, s && `${s} second${s !== 1 ? 's' : ''}`]
            .filter(Boolean)
            .join(', ') || "0 seconds";
    const totalMovingTimeFormatted = formatTime(movingTime);
    const totalHeartRateTimeFormatted = formatTime(timeInZones.reduce((sum, sec) => sum + sec, 0));
    let pieValues = [], pieLabels = [], pieColors = [], bpmRanges = [], formattedDurations = [];
    HR_ZONES.forEach((zone, index) => {
        if (timeInZones[index] > 0) {
            pieValues.push(timeInZones[index]);
            pieLabels.push(`${zone.name} (${zone.lower}-${zone.upper === Infinity ? `${zone.lower}+` : zone.upper} bpm)`);
            pieColors.push(ZONE_COLORS[index]);
            bpmRanges.push(`${zone.lower}-${zone.upper === Infinity ? `${zone.lower}+` : zone.upper} bpm`);
            formattedDurations.push(formatTime(timeInZones[index]));
    const pieTrace = {
        type: 'pie',
        values: pieValues,
        labels: pieLabels,
        marker: { colors: pieColors, line: { color: 'white', width: 1 } },
        text: bpmRanges,
        customdata: formattedDurations,
        hovertemplate: "<b>%{label}</b><br>" +
                       "Range: %{text}<br>" +
                       "Percentage: %{percent:.1%}<br>" +
                       "Duration: %{customdata}" +
                       "<extra></extra>",
        textinfo: 'percent',
        textposition: 'inside',
        insidetextorientation: 'radial',
        hole: 0.4,
        sort: false
    const layout = {
        height: 350,
        title: {
            text: `Heart Rate Time in Intensity Zones<br><sup>Total Moving Time: ${totalMovingTimeFormatted}<br>Total Time with HR Data: ${totalHeartRateTimeFormatted}</sup>`,
            xref: 'paper',
            x: 0.5
        margin: { l: 0, r: 20, t: 90, b: 20 },
        hoverlabel: { align: 'left', bgcolor: 'white', font: { color: 'black', size: 12 } },
        hovermode: 'closest',
        showlegend: true,
        legend: { orientation: "v", x: 0, xanchor: 'middle', y: 0.5, yanchor: 'middle', traceorder: 'normal' }
    return {
        data: pieValues.length ? [pieTrace] : [],
        layout: {
            ...layout,
            annotations: pieValues.length
                : [{ text: "No heart rate data available in defined zones.", xref: "paper", yref: "paper", showarrow: false, font: { size: 16 } }]
finalChart;
It’s a ‘puzzle’ …
Play with the order of the graphs and then decide if you want the chart to take half of the width or the full width. Sometimes the results are surprising, and not what you were after. Trying to get three columns is basically impossible. Some charts support scaling better then others.
Remember that the charts config isn’t adapted when viewing on mobile or desktop. What looks ok on one, probably isn’t on the other.
Probably not what you wanted to hear, but it is what it is.
Thank you. I understand. I’ll play around with it, and see if I find something that looks good :slight_smile:
