Activities time window to stay permanent (until changed again)
Hi All,
is there a setting that allows the time frame selected in Activities to stay permanent (until changed again)?
I don’t mean that I can click on a certain month but rather that this stays. So right now whenever I open intervals it opens with the current month selected. However, it actually just shows up to next week, it right now does not even show all of April even though at the top it says April 2022.
Then I would click and select maybe say May 2022, and now it shows all weeks up to the last one starting still in May. Great, this is what I want.
Edit: I just tested and "re-selecting’ April actually means that I then do also see the week starting 25 April.
Now I close intervals and later reopen it and it is back to April 2022 but just showing next week, not even all of April.
Is there a way to keep the May 2022 selected?
Edit: In Fitness, it sticks to my selected custom date range, it is that whenever I open intervals and stays until I change it.
Thanks,
Lenn
This one is a bit tricky. I am worried that if I make the default behaviour remember your previously selected date then people will complain that new activities are not showing up. The current behaviour (date remembered until app reloads) is a compromise.
And what if this is made into a setting? Like tick a box if you want to keep it until you change it? Then for people there would be no change but for others who want they can go tick the setting and have the date range not reset.
