Ability to split multi-day activities into multiple entries
I have activities that are registered as one long activity in Strava, but actually span multiple days (bikepacking, ultra-racing).
The computed load from those activities is only attributed to one day, despite the activity timeline properly showing that it spanned multiple days (24+hours).
Example:
Would it be possible to have a way to split those activities into multiple entries, so the training load would be properly associated with each day? It could be based on the intervals, or even a way to duplicate an activity and then use the crop feature to only select one day of data.
Cheers and thanks for your work!
Holy cow those are some epic rides! If you have the original fit file somewhere it might be possible to do something.
Haha thanks David, those are fun :slight_smile:
Yes I have the original Fit files in Garmin/Wahoo. Some of them were merged after the fact to make one big activity in Strava, while some others were recorded all at once.
Could you use fitfiletools to remove a section from the file and save the rest? It would be fiddly though. For the second day you’d need to remove day 1, save, reload and remove days 3 - N.
Also, Strava has a crop tool. Would that work?
You can already crop in Intervals (Actions > Crop).
Need to manually upload the fit file for each additional day
Gotoes can split them for free to tcx if you only have standard data.
If you have data not supported in tcx, there is a small one time fee to save to fit. All fields including dev fields are supported when exporting to fit.
Fitfiletools can also crop the data required.
Thanks for the answers all. I know about fitfiletools / cropping in Strava then re-uploading.
I was more looking for a way to do that directly in intervals.icu. Some of those activities are over 4 or 5 days, and that’s a lot of manual cropping/re-upload.
