sry i delete my strava acount and try to connect icu to another strava acount.The website shows {“status”:422,“error”:“Strava athlete is already linked to a different Intervals.icu account”}.Is there anything i can do to solve the problem?
Sounds like you have 2 intervals accounts. You need to login to your other intervals account and disconnect strava.
Please DM me a link to your Strava profile and I will have a look. But as Alex says if you can login with the old account and disconnect Strava.
this is my strava acount.
sry i cannot log in the older strava acountbecause it has been deleted.
I don’t see any Intervals.icu athlete with that Strava ID? Please try the “Connect Strava” button on the /settings page and see if it works now.
I have the same problem now - I had two strava accounts, and linked the wrong one to intervals.icu. I revoked access (on both of them) and I’m trying to pair it again, but I’m still getting {“status”:422,“error”:“Athlete is already linked to a different Strava account”}
I have cleared your old strava_id so it should work now. I need to figure out why that is happening.
Thanks! works now
Hi, I’m running into the same exact problem under the same conditions. I deleted everything from my stava account and then started a new one with the same email address. Get this error
Can you clear my strava_id and perhaps that will help?
Thank you
Hi, I’m into the same problem with message about “{“status”:422,“error”:“Athlete is already linked to a different Strava account”}”.
What I did:
0. At the bigging I had set up connection intervals.icu and strava. Everything was perfect.
- Decided to delete strava account and did it. Unfortunatell forgot to disconnect account strava from intervals.icu side.
- After deleting strava account, connection from intervlas.icu side is done “automaticly”. I can see button “Connect to strava” in Settings. Its done without my intervention
- When trying to connect to strava, I’m directed to Strava Authetication, then I confirm, and getting response “{“status”:422,“error”:“Athlete is already linked to a different Strava account”}”
- In strava settings panel I can see, that authorization was sucesufull, because intervals.icu is linked to strava account.
Please help.
Can you please message me your Strava ID and I will sort this out.
current atheld it is 137783450. Previus deleted profile id 87145424
my strava id is:
Thank you
i have the same problem, when trying to link strava i get the message:
“Athlete is already linked to a different Strava account”.
The connection appears under https://www.strava.com/settings/apps.
I tried to revoke it and add it again, it still happens.
my strava id is: 128520059
Athlete ID: i28652
I have removed that check and will deploy Tues AM (GMT+2). There might be some complications if someone changes from one Strava a/c to another and has activities from both. Editing the name or similar on an “old” one will fail.
i changed my email on strava maybe thats the reason. thnx for helping.
