In an activity in which the heart rate reading has clearly been wrong. Is it possible to update the Average Heart Rate to a more realistic value to minimize the error in the calculation of the rest of the parameters? I know that one by one the readings of an activity can be corrected, but that is not practical because there are so many
On the activity page : actions ā fix date ā fix heartrate ā scale = desired avg HR / current avg HR
ie if current avg HR = 120 and desirded avg HR = 150, scale = 150
It should change the avg Heart Rate according to your will
It has cost me to understand the operation but it is what I was looking for or even better. Iām going to test if I can use it only in the areas of the activity where the errors are. Thank you!
If you zoom in to the area with issues then it will only update that section.
Yes. Os Great!
