Switch left-right Y axis in custom charts
Hello,
I use several charts / custom charts and It would be really nice to have a way to switch the values (legenda) shown on the left Y axis and right Y axis.
I’m not sure if I understand your question correctly but you can change the description on both Y-axes from here
@MedTechCD
I’ve edited the title to “switch left-right Y axis”.
Basically I would be able to move the left Y axis on the right, and vice-versa when the right Y axis in shown. From your screenshot I can edit the axis, but cannot move what is on the left to the right, and viceversa
Thank you :slight_smile:
The first plot in the list is on the Left axis.
If you change the order of the plots, you can switch the left to right.
If you click on the three dots next to the Color, you can change the order
I don’t understand how to switch left to right; I’ve a chart showing Power on the left (and nothing on the Right); how can I move the legenda from the left Y axis to the right Y axis? it’s in a Custom Chart create by another user. Thank you
The first plot is on the left, the second is on the right. If you want to change left to right (that was your initial question), you have to change the order.
If there is only one plot or all plots are the same data, then it will be on the left. You can’t change it.
You could share the chart (name), or a screenshot, if we understand it wrong.
Ok @R2Tom
now clear, then it’s not possible. I supposed that my request to switch left to right was not requiring to also switch right to left when right is missing.
The custom chart name is “Power Chart”
IMO it would be nice to generally have the legenda on the right, because on the right you’ve the “most recent values” - having the legenda on the left requires eyes to scan back and forth and it’s not very usable. My 2 cents :slight_smile:
Are you talking a chart on the activity pages or on the Fitness page?
Asking because
Show us a screenshot of what you have and explain what you would like.
I’ve this:
And I would like to move the rectangle on the left, to the right
But you see the most recent values on the right, if you put the cursor to the right too.
yes, with mouseover yes, I see the current value.
But don’t you agree that the legenda on the right can also be usefull?
@MedTechCD is there a way to have two values on the left and two on the right? i.e I want RPE and ramp rate on the left axis and fatigue and fitness on the right?
Yes, works if you modify the axis for Ramp by clicking on the three dot menu and select same axis as RPE.
