My coach has added the workouts to the interval calendar. I enabled syncing in Settings by checking the three boxes, but I don’t see any workouts in the Garmin Connect calendar. I can’t see the workouts on my Garmin 1040 either. Why doesn’t it sync? Some can help me?
Can you take a screenshot of your settings?
Yes you can find here. I ve also synconized MyWoosh and now i can see next week in calendar with 2 workouts but in Garmin connect there is no way
you think the configuration can affect the synchronization?
Can anyone help me? I can’t find the workouts on my Garmin. I also activated sync on my MyWoosh and it works, although I don’t understand why some training zones are incorrect.
What is this filtering?
Remove it and let all workout types sync to start diagnose. If you don’t want some to sync, filter after checking connection first.
Training zones need to be matched on the different platforms. Make sure both have the same Threshold settings, LTHR/FTP.
Thank you !! now we find all workouts of next week !!! thank you ! i ve filtered it thank you !! other is ok? about Mywosh FTP is same probably read bad some instrusction…if on intervals WA my coach write Z1 i dind only 85 watt ![]()
