Request to add iGPSPORT integration
不是,我只是 ICU订阅者
If you can get in contact with someone there to follow this up, please do!
好的,我有他们工作人员的微信,你可以把你的联系邮件给我吗?我让他联系你。
any update on this? about to pull the trigger on a binavi air. thanks!
IGP 正在 沟通。
Unfortunately I haven’t heard anything from them yet.
SRY 说是因为一些政策原因。类似这种新闻: 关于顽鹿平台用户数据同步第三方平台功能调整的说明
If the limitation is due to policy or regulatory reasons, how is synchronization with Strava and TrainingPeaks still possible?
Is there a difference in how those integrations are implemented compared to a potential Intervals.icu integration?
I agree and they even have linked to Komoot.
If the Igsports Appp supports .fit file export you could try the approach below which uses dropbox as shared store which Intervals.icu can pole.
I use this on the Bryton app where there is no direct Intervals integration and it takes seconds after a ride. One of the advantages is that there is no restriction on Intervals onwardly sharing that data to other apps like you would if you used Strava as the transfer mechanism.
I have igpsport binavi and use this feature. I export the .fit track directly from igpsport app to Dropbox.
Obviously, you must have linked Dropbox to intervals, and for faster exporting, I recommend also installing the Dropbox app so you can share the file directly.
That seems easy enough until an integration is possible. Thanks!!
It seems an API has popped up. We have just mailed in a request for access.
Do you have any news @david ?
Unfortunately not :frowning:
