Power curve per month
Currently, under /power we can see the power curves for last 42 and 84 days. I would like to see a chart with my power curve per month. Is there a way to make such a comparison of power curves?
Yes power->power curves->for workouts(change to 30 day) and tick to show this
Thanks, that for_workouts I knew already. But that shows it only for the past 30 days. I wanted to have the powercurves of sept, oct, nov, dec, jan above each other. Like the one that you mention in fact but that does it for 30 (my for_workoutsvalue), 42 and 84 days. I wanted to have it per month.
Also, are the 42 and 84 values special (e.g do they come from science or were they chosen at random)?
42 is 6 weeks which is a commonly used duration for training blocks and so on. So not from science but I have seen it a lot.
To do months now you would need to create a season for each month which is a pain. I have added that to the todo list.
Also be careful with the for workouts one. Thats the power curve used when you create workouts using %MMP.
