Hi David,
Just noticed a bug in the way that CSV files of power duration curves are exported.
Here’s are how my power curves are displayed on the website for this season and last:
Last season’s longest ride was over 7 hours and this season’s only about 5 hours.
When you export the curves in a CSV file, the values from the longer curve, which should be in the third column (time, Power this season, Power last season), get put in the second column once the second column power values run out:
The values highlighted in yellow should be over one column as they are being incorrectly appended to ‘this season’
In the CSV file you need to have all of the commas in every row to keep the data in the right place.
Hope this helps.
Mike
