Hi, I did a treadmill run yesterday but there is no power data from Stryd showing. In garmin connect you have the data. I deleted the file and downloaded directly from Garmin connect and also reprocessed the original file but still no power data. Any idea what the problem is?
Same thing on todays run so there seems to be a problem
yesterday j had power from garmin wrist power meter (i know it’s not stry) just writing to narrow the problem
just confirming I did a run (outdoor) yesterday with Garmin watch and Stryd footpod and power was recorded to my activity fine.
Cheers
Those runs have 2 power traces, one all zeros which is what is causing the problem. I am working on a fix. Had some issues with my laptop that slowed things up somewhat.
Ok, maybe it’s because I have Stryd via ANT+ and Garmin HRM Pro via Bluetooth at the same time?
Today it worked however with this setup
https://intervals.icu/activities/i10627624
This is fixed now. Power streams that are all missing or zero are ignored so it picks up the Stryd one now. You need to do Actions → Reprocess file to fix existing runs. I did the original one you posted already.
