Motivation and Fitness chart
Not sure if this is intended, but when adding “Motivation” in the Fitness chart, higher motivation levels given in “Wellness” in Activities seems to make the Motivation line in the Fitness chart drop.
E.g. if I rate my today’s motivation higher than yesterday, the Motivation line in the chart drops (rather than rises).
Those wellness fields are setup so low numbers are “good” and high numbers are “bad”. This works for soreness, fatigue and stress but not so well for motivation.
Perhaps just rename “Motivation” to “Apathy”? “Ennui?” “Existential Dread” ? Resignation?
Then the directionality will make sense.
You can use an icon of Edvard Munck’s “The Scream” for the worst one.
Ummm…sorry…I’ll stop.
I like the scream idea. I went with higher = bad for these to match fatigue and so on.
