Hi, I realise I am not a supporter at the moment and that some restrictions may apply but since starting to use the platform a couple of weeks ago indoor trainer data has succesfully uploaded from Strava inluding length of workout,power,cadence, speed,distance and HR.
Today the data only included length of workout and heartrate.
Is there anything I can check in settings or is there an issue today?
You are getting workouts from Polar and Strava. Intervals.icu will delete Strava activities in favour of the Polar ones. However it seems that Strava is supplying power data but the Polar ones only have HR. I am not sure why that should be but maybe you should just sync via Strava?
Polar: Intervals.icu
Strava: Intervals.icu
Hi David
I use Polar hr sensor which I assume will be why the data from Polar is only HR.
Curious as to why this has not happened before, but no problem in removing Polar connection.
Regards
Alan
