I have fixed this. You can now specify the activity type when setting eFTP:
Wow, that’s fab. Thank you.
Hi, first, thanks for the site, awesome resource!
I had an ACL operation back in November. I’ve been on the turbo the last few weeks, and noticed that the site had my eFTP much higher than I believe it to currently be (266W - I tested at 233W a couple of days ago). I’ve set a manual entry of 200 back on my operation date, but from what I can see it doesn’t seem to have propagated forwards through the 30 or so activities I’ve done since then?
Thank you!
I have the same issue.
Change from Garmin power to Stryd power for running and wanted to reset my eFTP from that date on in the past.
Unfortunately the running eFTP in the settings isn’t updated
I’ve tried it, and it worked (not with a Run, but with a Virtual Ride). It must be on a day where this activity type happened, did you try this?
That did the trick!
Thanks for sharing ![]()
