When I use my garmin headunit with gps function off (when I can’t be bothered to also load up Zwift) , intervals.icu totally screws up my time in zone and as a result also says I only completed 30% of a workout which I actually pretty much aced. The graph shows my workout nicely, but when I go over to the TIZ page, it only reports a total of ±16mins (it was really 42mins)
How can I solve this? It seems as if it needs GPS data + speed to be able to properly calculate time in zones?
@david It seems as if my Garmin recorded it with 9 sec intervals for some reason, but that shouldn’t be too big of an issue though should it? Intervals.icu
9 sec per point is ok, that just makes it impossible to match laps recorded on a device back to the underlying data. The problem is that there are lots of big gaps in the data. You can see if you download “Streams CSV” on the activity data page.
The dark column is time in seconds.
Those gaps are too big so Intervals.icu doesn’t count that time. You can see if you mouse the marker over the chart. It jumps between points.
