I spotted a ride obviously indoor but with GPS data and “trainer: false” from Stava. The moving stream was very on/off. The Intervals.icu training load and lots of other stats were broken as a result. Intervals.icu will now ignore the moving stream from these. If you have any you can click “Reset” under the ride timeline chart to sort them out.
I noticed that the problem is, when Strava takes a virtual ride file from another source, either non partner or manually uploaded (and also when for example uploaded to Garmin and then that syncs with Strava), it will always mark that as a normal ride. What can be done to prevent that?
Even if you take a ride marked as virtual, download that from Strava (original or GPX), then delete it and upload it again, it becomes a standard outdoor ride…
I sync my rides to Garmin and they are pushed to Strava from there. I found that if I turn off the GPS on my Edge 500 for indoor rides then they get “trainer: true” and something estimates the distance (not sure if thats Garmin or Strava).
They’re more funny to see how you seem to move all over your neighborhood while sitting in the same place, if GPS is left on ![]()
It must be the Garmin calculating distance, form trainer speed. It’s the same when I use the Tacx app to control and record a ride on my Neo. Obviously, that has no GPS at all, but it does calculate distance from speed.
