Hi @david
I found importing a workout from Training Peaks, with the ERG format, that steps that had the text “100 rpm” resulted in the step to be ignored. If I changed that to “100rpm” in intervals, that step is then used.
I have an example ERG file, if you want it.
I hope this helps.
Thank you.
