I have an older workout with bogus data (3 min/mi run!!). I thought by deleting in Strava i would clean-up Intervals.icu. Not the case. The Intervals.icu workout persists and now i can’t delete because the Strava workout is missing.
Apparently not, if you have deleted the workout in Strava. When I try to delete it gives me an error message, indicating it can’t find the Strava workout.
It gives an error message, but does it delete the workout in intervals.icu? If it does, then you likely can ignore it.
Strava’s T&C dictates that if you disconnect the link (strava ↔ intervals.icu) then intervals.icu is obligated to remove all (strava sourced) workouts. However ,it looks like you’re only trying to remove One. Hence, this shouldn’t be the issue.
