Export cadence RPM to Garmin? [ Solved - No Option from Garmin]
Is it possible to export cadence rpm values set in a workout to Garmin?
Even if it’s possible, I don’t know if these are possible showing these in Garmin computer during a workout.
I don’t think so. You have to choose a target for the step and its either power, HR or cadence. You can’t combine as far as I can tell.
(I think there are also pace targets but I haven’t done that yet)
If I write the fit file like this:
  • 20m 76-90% (194-230w) 85-105rpm
Garmin computer will show only that you have to hold for 20 minute this power range but it’s not showing the rpm.
Is there anything that I’m missing?
The fit workout format and the Garmin JSON workout API doesn’t support more than one target for a step so only power, pace or HR. No RPM.
