Edit data - range edit
Is there a way to edit data in a range; eg. for a badly behaved HRM that had a spike for 60 seconds? starting and ending values.
If you zoom in on that portion of the ride then you can use the “Fix data” option which only applies to the visible portion. The “Edit data” manual update also starts with whatever you can see on the chart.
