Differences in Decoupling on Activity Power
Hi.Does anyone know have any idea why I get 2 different decoupling values on this activity. The main one at the top shows 5.1% for the time period selected but the one at the bottom shows -1.4% for the same period.
thanks
The bottom one is showing the information at the point your cursor is at. In this case at 8:15 of your ride. If you move your cursor over the graph to left and right, these values are going to change. The upper values are the average values of the entire period selected on the slider.
Thanks but thats why I think they should be the same at the same point on the ride as the top one shows the decoupling for whole time segment selected.
That chart works a bit differently to the others:
Decoupling is a 10m moving average of the power/HR ratio relative to the ratio for the first half or hour of the ride whichever is shorter.
So it shows you when you experienced decoupling and how bad it was. You can also just look at when the power and HR traces start drifting apart. The chart fiddles the low side of % HRR and the high side of power / eFTP % so the traces start off overlapping nicely to make this easy to see.
Thanks It would be cool if someone could write a Garmin IQ app that could show it in real time on a ride. Anyone???
I would look on Garmin CIQ, but all services are down today :zipper_mouth_face:
There are such CIQ fields that estimate decoupling. When the garmin IQ website starts working, look for yourself. However, the functionality is so-so.
Thanks, yes I found one, but as you said, the functionality of it was so-so to say the least. The guy who wrote it actually says in the description that he doesn’t have a power meter so he couldn’t test it.
