That works nicely - I have updated the stream definitions (including gear index and ratio - only difference was also keeping front/rear_gear_num). Hadn’t thought of using the “irrelevant” fit messages as a way to set the data. Not entirely sure I understand why it might work better, but it seems to have helped.
This 12-hour activity still fails with Memory limit exceeded though: i20126210
Hi, when I use this with my sram etap group it seems that the previous values aren’t repeated till a new shift.
Is there a way to enable something like a “if null keep previous value” in charts? That would make this chart a lot clearer for moe
I updated the script for the custom stream plotted on that chart to use the previous value instead of null. Now the chart fills in nicely. You need to do Actions → Reprocess file to get this for other activities.
