Comparing rides?
Morning all
When looking at the power PBs for 15s, 60s, 5m etc. you can easily compare to season and all time.
Is there a way to compare it specifically for 2 rides? For example comparing the stats for Tuesday ZRL last week and week before
Great idea - would be very helpful.
Right now you need to use 2 browser windows. I need to think about how that might work in the UI. Its tricky.
Thanks David
I didn’t even think about opening a separate browser to compare!
maybe it helps as reference - you can check on quantified-self.io there this feature is implemented
Second this request, ideally a way to overlay or even a table of two (or more) different rides or intervals within rides). Or to start, just comparing on the power curve page? IE remove recent days / season / etc. and instead select a specific activity. In this screengrab the closest I’ve gotten is selecting a narrow date range (shows in pink, but hard to discern).
Comparing activities on the /power page is a good idea and might not be too hard to implement.
