I am going to use the note next to my name (see image) for my bike fit info. It will stay unless I erase it, correct? I didn’t see anywhere else to put it.
Is there a better place? Could there be? Should there be?
Yes, the note next to your name on the calendar is a good place to put your bike fit info. It will stay there unless you erase it.
There is no other dedicated place on the calendar to put bike fit info, but you could create a custom event type for it. This would allow you to track your bike fit info separately from your other events, and you could also add additional fields, such as the date of your next fit or the name of your fitter.
