If I select w/kg as my display preference for my power curves, shouldn’t best efforts also prioritize w/kg rather than continuing to prioritize absolute watts?
My w/kg for several effort lengths are higher for “this ride” on the ride power page and higher for “42 days” on power page, yet they are not the “this season” best efforts because they are slightly lower in watts even though I am 5kg lighter.
Can the w/kg option be made universal priority on the page if desired?
That w/kg setting is local to the browser and not “server side”. What I need to do is track best efforts in watts and w/kg server side, track achievements separately etc… I plan to revisit best power achievements and generate those whenever you bump up the power curve, not just for the specific “best effort” durations. Should be able to get this done then.
I think this is also what I’m seeing: I hit 170W for 1 hour twice recently (9/Nov and 13/Dec), but by December I had dropped 2 kilos so my W/kg improved from 1.65 to 1.70 even though absolute power was the same. But the 13/Dec ride (170W, 1.70 W/kg) isn’t shown in “best efforts” because it didn’t achieve higher absolute power.
If absolute watts are generally given priority, then I’d suggest there’s an edge case here, worth handling by checking W/kg as a tiebreaker to show the ride with highest W/kg if two or more have the same power level.
But if W/kg is the overall priority, as seems to be the case, then this is definitely a bug. For any given rider, a ride with equal absolute power but higher W/kg is a bigger achievement and should be prioritized in the display.
This is a limitation of the current system. The best efforts chart works on watts and the w/kg is worked out afterwords. I have a todo list item to sort this out.
