Is it possible to add also dew point to the weather forecast in the activities?
The weather API I am using doesn’t supply dew point. I did find a formula for dew point using temp and humidity but what temp should be used? The min, max or average for the day?
This link should help with calculating formula for dew point base on temperature and humidity.
Dew Point Calculator | Good Calculators
You can use it the same way as a daily range in the summery information you displaying for the day temperature and wind, and when clicking you can display it hourly as you doing it today for temperature and wind .
