60d and 42d moving average not working for weight
When I select the longer moving averages, they all start from 0, rather than from the first moving average value calculated outside the window.
Does not seem the case with other metrics like HRV, where it works correctly.
If I change the display window, the problem is still there.
This is fixed now. There was also another bug with weight and several other wellness fields that caused days with missing data to be included in the average. Luckily I have some of those. Unfortunately I am now fatter than the 60d average first suggested :frowning:
Forgot to mention that you need to delete and re add the plot to get the fix.
Thank you! Works great now
